87 350 TPI discharge hose P/N?
Old Nov 29, 2018 | 09:56 AM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
Hey all,
I'm looking for a p/n for a discharge hose for an 87 Camaro 350 TPI. I have already ordered two different ones from summit that are wrong. 55451 is for a passenger side mounted compressor and 55452 has the line routes down through the mounting bracket at the back of the compressor.
4 seasons says 55497 routes over the top of the compressor like it should but the part matches a 2.8 not a 5.7.
Any help would be appreciated.
Old Nov 29, 2018 | 10:18 AM
Drew's Avatar
Re: 87 350 TPI discharge hose P/N?
For the A/C? No one offers the hoses for the 87 system. It's one year only, and most of the aftermarket is under the mistaken impression that 87 was a full serpentine system.
The six cyl lines are probably closest but they're still not right.
Old Nov 29, 2018 | 04:37 PM
Engine: 383 HSR EBL
Well isnt that just wonderful :/
I'll just keep looking for a serviceable original part. I wish I did not throw out my original but I thought I had the right part at the time...
Thanks for the reply.
Old Nov 29, 2018 | 10:27 PM
Drew's Avatar
If nothing else, look for a used set, and find a local shop that can crimp new rubber onto the old manifold/tubing. A good hydraulic shop, A/C shop, or even a well outfitted parts store may have the tooling necessary. That's my plan if I ever need to change the hoses. As it worked out, I think my leak is from the seals on the original compressor. It's on my someday list to get the leak fixed and recharge it... Maybe this spring. Maybe.
J.C. Denton
Jul 29, 2015 03:23 PM
anesthes
Feb 4, 2002 07:04 AM
superiroc
Dec 29, 2000 01:19 PM
