Radiator blew
Old Apr 13, 2019 | 09:08 PM
allos's Avatar
Car: 89 GTA, 84 T/A
Engine: L98 stock, Carbed 350
Radiator blew
Something went wrong with my cooling fans, which I haven't tracked down yet. Causing the car to overheat while sitting, and blowing the radiator.
Do I need to worry about coolant having gotten mixed in with the transmission fluid?
Old Apr 14, 2019 | 11:03 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: Radiator blew
Probably not. I'm assuming by "blowing the radiator" you mean it boiled over, but even if it cracked its unlikely to have damaged the cooler lines inside. Just pull the tranny dipstick and it's nice and red and not frothy you are good.
Old Apr 14, 2019 | 12:59 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Radiator blew
Not sure what you mean by "blowing the radiator," but unless it literally exploded due to a crash or some other physical damage, splitting the core and frame, the trans cooler section was probably unaffected. It's easy enough to check---pull the trans dipstick and have a look. If the trans fluid proves to be contaminated, it's not a big deal to drop the tranny pan and replace the fluid and filter.
Old Apr 15, 2019 | 07:12 PM
allos's Avatar
Car: 89 GTA, 84 T/A
Re: Radiator blew
I would have responded sooner but got busy, and was unable to get out and take a picture.
Do you think it damaged the transmission cooler section, allowing the fluids to mix?
Old Apr 29, 2019 | 12:20 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Re: Radiator blew
Those plastic end tanks on the stock radiators are total crap. I lost count of how many I've gone through. Take the car to the shop and they just pop on a new plastic tank and it will go a couple three years and crack again. I have decided that next time I have a cracked tank, I'm going with a full replacement aluminum radiator. Phooey on that plastic s**t.
Oh, it is unlikely your auto tranny cooler was damaged. Regardless, check the oil in the tranny to see. Should look like cherry syrup on a snow cone. If it is milky or foamy or dark brown, time for a change.
redraif
Jun 22, 2005 11:31 PM
Frank_Blotto
Mar 23, 2005 10:13 AM
Kandied91z
Jul 30, 2004 12:46 PM
jfawcett10
Jan 4, 2004 05:33 PM
