Hey guys....got a question. I have an 82 T/A and Im having issues mounting the belt driven fan assembly back on to the water pump without it hitting the lower fan shroud. Any ideas what may be the cause? I dont remember having to use a spacer for this part in the past. When i bought the car initially it was missing the upper and lower shrouds. I bought a new fan clutch from autozone....now im guessing it may be the wrong one? Thanks in advance.
Sorry...its the fan blades rubbing against the shroud. No clearance.
8t2 z-chev
close
- Join DateJan 2009
- Locationbelle fourche,s.d.
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car'82 z28
- EngineL83 5.7
- Transmission700r4-1985
- Axle/Gears3.42 posi
- Liked:116 Times in 100 Posts
could be wrong fan-firebirds used a 17" fan.
I actually had the stock fan and them bought a replacement thinking it was warped. Nope...still an issue.
I bought a flex-a-lite fan which is 17 inches. Still rubbing the bottom shroud. Maybe I need a spacer for the fan clutch to clear the bottom lip of the shroud?
8t2 z-chev
close
- Join DateJan 2009
- Car'82 z28
- EngineL83 5.7
next area to check would be transmission mount at the tailshaft-if that is too high,wrong mount,bent x-member,etc., it will rock the engine forward on the mounts and bring the fan down into contact with the shroud-normally there is more than 1/2" of clearance.
