Thermostat housing removal and re-install
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Car is an 88 LB9.
Is there some special tool to get to the bolts on the tstat housing? I can barely get a combo wrench on them, and then I can only go like 1/16 turn at a time.
There has gotta be a better way.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Thermostat housing removal and re-install
If you remove the Throttlebody you have more access to the inner bolt.
Car: 1987 Camaro Z28
Axle/Gears: 3.08
I just used a socket with a long extension when I replaced my thermostat, the bolts came out pretty easy putting them in you need to be careful they don't cross thread though
Car: 90 Formula / T-tops
Transmission: MD8
i feel your pain. if u are careful the gasket will be ok. it’s the cooling hoses that are a B
Car: 1989 IROC
Engine: 5.7 TPI
Axle/Gears: 2.77 Posi
Just remove the 4 bolts in the throttle body and push it aside far enough to get access to the t-stat housing bolts. Trust me, it's 100 times easier than trying to get those bolts out with the throttle body still in place.
You more than likely won't need to replace the throttle body gasket, but so what if you do? It's probably 5 bucks.
zman1969
Jul 14, 2011 03:50 PM
bobdole369
Apr 24, 2006 07:37 PM
