89 305 with TBI single fan, need a replacement fan. Which one?
Old Jun 4, 2019 | 11:52 AM
JonnyThrice's Avatar
Car: 1989 Firebird KITT Replica
Engine: 305 TBI L03
Hey all! So the fan on my 89 Formula TBI seems to be dying. It's starting to make horrible noises and is kind of vibrating all over the place, so it seems to be time for a new one. My car has the SINGLE FAN setup.
Since my car is pretty much stock, I just want an easy replacement fan. I only see the blades and motor available separately from places like RockAuto, should I just go with those? Or is there some other fan anyone can recommend? I dont see the whole assembly avaialable anywhere. Thanks!
Old Jun 4, 2019 | 01:57 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: 89 305 with TBI single fan, need a replacement fan. Which one?
If it's vibrating and making noise replace the motor before it takes out your radiator or stops working completely . Pretty easy job, you'll need to remove the whole fan from the upper and lower shroud pieces and unplug to get it out. As long as the blade is good it should work fine
Motors available almost anywhere. Google it. range from cheap to better to suit
https://www.google.com/search?source...60.8W0pXfrbF_Y
norcalz28
Dec 19, 2010 01:09 AM
91 camaro rs
May 14, 2007 01:02 AM
Damon
Aug 2, 2003 05:55 AM
aziroc
Jul 19, 2002 02:44 PM
