92 RS stock single fan- single speed or dual speed?
Old Jul 30, 2003 | 06:41 PM
Damon's Avatar
Have an all-stock 92 RS with the 5.0 TBI engine. Uses a large single electric fan from the factory. It's only got 2 wires going to it so I assume it's a single speed fan (on or off) but I'm not sure. Maybe the factory has dual relays powering it for low and high speed. What's the correct answer?
If it's dual-speed what are the criteria for when it runs at low vs. high speed?
Old Aug 1, 2003 | 12:51 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Damon,
Hey man, what's happening!?! From the wiring scematics, it's an on or off operation. Are you having cooling issues?
Old Aug 1, 2003 | 02:58 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Read Willie's article above, on single fan systems--tell U everythin U want to know!!!
Old Aug 2, 2003 | 05:55 AM
Damon's Avatar
Thanks.
Cooling is fine on any day that's not in the 90s. But drive around in stop-n-go traffic for a while with A/C on and it doesn't keep up. Not overheating, but running hot. The radiator and waterpump are not the originals but have unknown mileage on them. Car and engine have 197K on them, but are in good running condition. Just trying to check simple stuff before I replace everything in the cooling system.
onefreakz
May 14, 2018 12:15 PM
InfinityShade
Aug 22, 2015 08:00 PM
jbd1969
Aug 17, 2015 07:06 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
