Coolant Temp Connector
Old Jul 13, 2019 | 03:21 PM
ksj4477's Avatar
Hello, I have a 1984 TA with a LG4 engine that I am fixing up. It has a broken temperature sensor connector (see pics) that I am wanting to replace but I've searched on here and google but can't seem to find it. It's on the thermostat housing and has a black and yellow wires coming out of it. I've seen similar ones but have one wire coming out of it and the center of it is male instead of female so it won't work. If I can't find this connector can I switch to a newer style 2 wire sensor that has the prongs side by side?
Thank you!
Current state
End of connector
Locking mechanism
Sensor/sendor
Old Jul 13, 2019 | 03:47 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Coolant Temp Connector
https://www.repairconnector.com/
I think it might be this one: https://www.repairconnector.com/gm-c...epair-pigtail/
Old Jul 13, 2019 | 04:17 PM
ksj4477's Avatar
Originally Posted by T.L.
Thanks for the reply. I've looked at the second one you show there, the locking mechanism looks the same but it's a single wire instead of a double wire like I need.
Old Jul 13, 2019 | 04:38 PM
Get rid of it. It is THE DUNG. Always has been, always will.
SOOOOOPER EEEEEEEZY to put an end to that garbage once and for all.
https://www.autozone.com/engine-mana...48732_882720_0
Throw the Scothcloks in the trash. Use solder and heat shrink instead.
Old Jul 13, 2019 | 04:56 PM
ksj4477's Avatar
Great! I actually already have that connector because I thought that is the one I had until I went to replace it, I'll just have to buy the sensor. Thanks for your help!
Wolfman720
Jun 9, 2019 05:36 PM
ben73
26
Mar 1, 2016 11:22 PM
Veaceonee
Jul 16, 2013 05:14 PM
SomeGuy25thZ
Aug 12, 2010 08:56 PM
Crazy1bob
Apr 17, 2004 02:19 PM
