Correct ACDELCO Coolant Temperature Sensor for TPI
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
I have a 1986 Camaro IROC Z. When searching for a replacement CTS I see there are two Ac Delco and two BWD part numbers listed for my car.
There is ACDelco 213-928 and ACDelco 213-4396. Which is the correct Coolant Temperature Sensor?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Correct ACDELCO Coolant Temperature Sensor for TPI
They are basically the same. One Delco is 'OE', the other is 'Pro'.
AFRO IROC Z
Jun 20, 2001 10:34 AM
