r290 in a stock r12 system
Old Jul 19, 2019 | 09:55 AM
RandyNJ's Avatar
Been looking up ways to charge my ac. Read all about the 134a conversion and all the others. I don't currently have the money to spend a few $100 on a conversion, so was looking into cheaper methods. Found envirosafe r290 which seems to have mixed results. Pretty confident in my decision to use it, but there's multiple different types and I wasn't exactly sure which one is recommended. Also, was hoping someone could give some information on it before I go blow myself up or light the car on fire
Or should I just run 134a in my r12 system and if it leaks out it leaks out or if something breaks then I have to spend the money when I have it?
Old Jul 19, 2019 | 02:20 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: r290 in a stock r12 system
Get some R12/ebay on Craigslist and be done with it. Be sure and go online and take the test for purchase license. I'm sure the seller will want to see it, before the cash.
Old Jul 20, 2019 | 11:48 AM
RandyNJ's Avatar
A.c. recharge psi reading full, but nothing comes out of the valve stems if pressed. Compressor also isn't kicking on. Any idea what may cause this?
Old Jul 20, 2019 | 08:03 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
If nothing comes out of the valve stem, there is no refrigerant. No refrigerant, no pressure, no pressure, no compressor turn on.
Old Jul 21, 2019 | 10:18 AM
chilliewillie's Avatar
Dont know about any r290 but the retrofit for 134a isnt that difficult and 134a wont give you any kind of adverse problems down the line. Converted my 90 corvette to 134a, works great and Im in LV. All you have to do is pull compressor out, pour out and measure any oil that comes out. Replace accumulator and do the same as comp. pour out any oil from old one. Measure total amount you get from both. Add 75% of measurement back to compressor with new PAG oil (making sure you pour it in suction side of compressor. Thats the big pipe side) Put rest in accumulator. Pressure check and while you do this step add nitrogen to high side and watch low side gauge. Should come up fairly quick, if not you must replace orifice tube which is in line going from condenser to evap. Once it holds pressure and your confident orifice is clear. Evac and recharge 10% less 134a that r12. Ideally you should replace low pressure switch install a clutch cycling switch but it will work ok without. With the clutch cycling switch it allows the evap to get down below 32* and get colder air out of the vent without freezing it up. Good Luck
Old Jul 21, 2019 | 12:08 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I use R152a aka Keyboard Duster air myself. Get a side tap and side pierce the can. It cost me like $5.00 to recharge a vehicle and the stuff gets colder than R134a ever thought about.
Old Jul 23, 2019 | 10:36 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Chilliewillie, I'm not sure what you mean by this. The low pressure switch does cycle the compressor. Can you explain this more?
Old Jul 23, 2019 | 04:36 PM
Let me rephrase that. Its been my experience that most auto AC shops out here (LV) when converting from r12 to 134a they add a clutch cycling switch and replace LPS because 134a pressures keep evap below freezing. The CCS turns off compressor for so many seconds every minute which keeps evap defrosted enough it doesn't freeze up and blows out colder air, than r12 because its under feezing temp. Technically if you leave the r12 LPS in it would cut out compressor too soon thus not getting the most out of refrigerant and warmer discharge air temps. But it has also been my experience that in real world auto ac isnt a perfect science and conditions vary too much to get that **** about it. Since discharge air temp varies with rpm it doesnt really matter if its 38 or 48 while driving around town.
Old Jul 23, 2019 | 10:57 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Mine gets into the 30°F range before it switches off. I usually add the late 80s cadillac thermal cycling switch on the evaporator inlet and adjust the cycling switch to cut off about 20 psi. This lets the evaporator get just below freezing and cycle off when the temperature gets too cold.
GeneralDisorder
Jun 18, 2018 02:32 PM
quisterio
Sep 17, 2012 11:11 PM
Military Clone
Apr 17, 2011 09:15 PM
Zrated83
Aug 24, 2010 07:02 PM
Jstcrzyengh
Oct 15, 2002 02:40 PM
