86 camaro 305 heater core bypass
Car: 1986 Chevy Camaro Berlinetta
Engine: 305 V8 5.0 carb.
Transmission: Automatic
Axle/Gears: the kind that came with the car...
Do I have to drain all the antifreeze from the cooling system to attach the 3/4 5/8 hose from water pump to engine block? Please don't me hate for asking a stupid question I just need to know if I can do this without draining the entire system.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 86 camaro 305 heater core bypass
You don’t have to drain the whole system but you should bleed out the air after you connect the two hoses.
https://www.homedepot.com/p/SharkBit...7LFA/202798048
