HOW TO: Flush the coolant system???
Old Aug 7, 2007 | 08:58 PM
kdxrider9262's Avatar
Car: 1987 IROC-Z Camaro
Hello again
Im trying to get my car titled and plated tomorrow and I need to flush my cooling system after that TB heater hose blew ....I need to flush it because the the guy who owned the car before me tried putting stop leak in it to try and repair the heater core.....needless to say he failed and we ended up bypassing the heater core.....I bought a flush tee and 2 gallons of antifreeze......I was thinkin of hooking up the tee to where the heater core would be....but I really have no clue how to flush a system......any guides or ideas?
Old Aug 7, 2007 | 09:24 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: HOW TO: Flush the coolant system???
Thats where the tee goes on the heater hose, most of the flush kits come with a diagram.
Old Aug 7, 2007 | 10:04 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Why bother with the T? Pull the thermostat since you're going to replace it anyway and have some fun.
Old Aug 7, 2007 | 10:38 PM
ugh? why am I going to replace the thermostat?........and I didnt buy a kit.....i just bought the tee
Old Aug 8, 2007 | 03:25 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Well, you need the Tee and the adapater to get the hose on there. Hopefully you have the adapater...
Old Aug 8, 2007 | 03:34 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i did the wet way.. just pop off both hoses from the radiator and shove a water hose in the upper rad. hose, then let her flow.. then after you finish that, rad. cap off and hose goes in there to flush that out.. gets a bit wet so wear your speedo..
Old Aug 8, 2007 | 01:40 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, I never knew there was a kit for this... That's like an "oil changing kit". Just get'er done! I would remove the t-stat the coolant jacket plugs in the block and let 'er go. I also used drain ***** instead of plugs, so that's easier. Then also flush out the rad, and the heater core, and you're done.
Old Aug 8, 2007 | 01:43 PM
lol thanks for all the replies guys! I just ended up calling my dad and hes gonna come over and help me with it> Hate callin parents for help hahah
Old Aug 9, 2007 | 07:30 PM
Wheel Spin's Avatar
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
Prestone make a good and cheap ($5 ?) kit. Picked mine up at Autozone.
http://www.prestone.com/products/fla...cessories2.swf
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
89 formula TPI
Oct 6, 2015 08:40 PM
Stryker412
Sep 20, 2015 06:59 PM
TheExaminer
Sep 7, 2015 08:34 AM
