Coolant hoes for Champion 4row radiator
Old Sep 14, 2019 | 10:47 AM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I’ve been gone awhile due to medical issues. I’m starting to work on the car again. 1991 Firebird with a built SBC and a Garrett 80mm turbo. It’s almost done but I bought a Champion 4 row radiator. It will fit. I just need suggestions on what hoses to run. 1 1/2 to the intake and 1 3/4 to the pump. It’s still all in stock location. Thanks for the suggestions.
Pic for what I’m up against
Old Sep 14, 2019 | 10:54 AM
Car: 91 Firebird
Engine: Turbo 355
Re: Coolant hoes for Champion 4row radiator
The radiator is for a 1969 Camaro btw
Old Sep 14, 2019 | 11:08 AM
skinny z's Avatar
Do you think a hose this shape would work? My Griffen rad has an 1 1/2" inlet and 1 3/4" outlet.
Upper hose is: https://www.napaonline.com/en/p/NBG7240
Lower hose is: https://www.napaonline.com/en/p/NBG7042
(No pictures of the lower hose)
Old Sep 14, 2019 | 04:30 PM
Car: 91 Firebird
Engine: Turbo 355
my alternator is now right on the drivers side. I could try? The car is so close to being ready. Damn hoses.
Old Sep 14, 2019 | 04:31 PM
Car: 91 Firebird
Engine: Turbo 355
It’s worth a shot. Thanks for the links.
Old Sep 14, 2019 | 05:26 PM
Car: 91 Firebird
Engine: Turbo 355
Here’s more shots on where I mounted the alternator.
Old Sep 14, 2019 | 06:39 PM
skinny z's Avatar
The bottom hose should work for 1 3/4" to 1 3/4" unless you've got something unusual gong on near the water pump.
I'd say that the upper hose isn't going to work. The drivers side alternator was how my 86 IROC was set up. That hose was a twisted looking thing designed to go around the alternator and alongside the rad support. That might be worth a shot but you'd have to graft on a suitable 1 1/2" end at the rad as it's 1 1/4" factory. Stuff you may already know I suppose.
Did a quick look for 1-1/2 to 1-1/4 rad hose fittings. And 90 degree fittings as well. Came across these guys. Might be something here you can build but I can't comment on price or availability.
https://www.acehose.com/silicone-radiator-hoses.htm
Old Sep 14, 2019 | 09:00 PM
Car: 91 Firebird
Engine: Turbo 355
Thanks. I’ll look into it. Just need this junk on the road.
Old Sep 15, 2019 | 07:57 AM
Car: 91 Firebird
Engine: Turbo 355
Thanks bud. I think that will work for the top hose. Bottom hose I’ll get through Napa. You’ve been a big help friend. Much abligded
Old Sep 15, 2019 | 10:32 AM
skinny z's Avatar
My pleasure Zachary. Good to see you back.
In a pinch, to get you on the road again there's always the trusty flexible hose too.
Old Oct 10, 2019 | 06:38 AM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
If you have any pics of how your turbo is mounted I’d like to see them please. I’m looking at mounting a S480 in th same spot basically
Codornothing
Jul 21, 2020 08:06 AM
zacharyhorn
Apr 19, 2018 02:52 PM
Bmv5
Feb 5, 2010 08:53 PM
warrior_91
Jun 19, 2003 01:58 PM
