SD vortec base question
Old Dec 23, 2019 | 10:16 PM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
98 vortec block from a suburban.......
Turned it into a 383.. my question is, on the front do i need to put in the hose going from the water pump to the intake?
I think its a bypass something rather.....
Old Dec 24, 2019 | 10:06 AM
brian p's Avatar
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
Re: SD vortec base question
I've got the same block, with a vortec based HSR intake, here's a pic of that bypass hose connected so I'd say yes.
Old Dec 24, 2019 | 10:43 AM
happyhapka's Avatar
Ok, thanks... when its all warmed up how firm are your radiator upper and lower hoses, i can squeeze them but not too much they are pretty hard.
Old Dec 26, 2019 | 02:41 PM
brian p's Avatar
Car: 86 IROC
Can't say as I've checked the hoses but I have changed the temp sensor in the block and converted to Autometer Pro Comp Ultralite gauges ( so better than stock "guess the temp" ones) and the car runs no more than 200 degrees.
Brian
Doppelganger
Mar 8, 2024 06:56 PM
ponchoz-28
Apr 26, 2017 09:37 PM
NEEDforSPEED
Aug 22, 2006 11:28 PM
ecmagee1984
Dec 23, 2005 08:20 AM
1tinindian
Apr 15, 2003 10:26 PM
