Vortec 5.7 block with TPI 350 heads??
i getting a 2000 vortec short block it should be here with in the week,
i would like to know if mine "083 casting" 350 tpi heads well work on it, i heard that the coolent passages are diffrent?
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
What's the casting number on the block?
The term "Vortec" seems to be used rather loosely at GM lately. The 4.8L, 5.3L, and 6.0L, IIRC, are all labeled "Vortec", and were in 2000 + trucks.
If it's an L31 5.7, 350 cid block, then they'll work.
The only engines to have the "strange" coolant passages were the L99, LT1 and LT4.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Check to see if the main # on the side of the block is 880.
That one was used up to 2000 and it will work with 083 heads.
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
the only odd coolant passages is the absence of the water pump bypass in the block. its the little hole below the w/p bolts. you will need a water pump bypass, so you will have to run a small hose to the intake manifold to acomplish this.
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Hmm I know the LT1's and LT4's have the f'd up coolant passages, not sure what else would, but I doubt the truck "Vortec" engines do.
Car: 1989 C4
Axle/Gears: 307
Like Don mentioned up to 2000 engines are fine. Same as the Vortec 305 in my Camaro which only has one difference in the short block, that being the timing cover is not interchangeable with older style SBC. So your going to need a CPS or risk installing a freeze plug into the plastic cover. These late model vortec engines are a very nice platform to work from so have fun and dont worry about coolant passages ect.
Follow up on that block
Some don't have that coolant hole but most do.
The timing cover from the L98 will work if you get two 1/4" dowel pins and drive them in for the cover to align on.
On the ones without the coolant hole, I just drill two 1/8" holes in the thermostat.
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Just so that I'm clear.....I'm thinking of getting an L31 partial shortblock, but just kinda realized that it's a reverse-
flow, serpentine motor.....mine is a standard rotation v-belt drive motor. Will it somehow work anyway?
Car: 94 C1500
Transmission: NV-4500
Axle/Gears: 3:42 10 bolt 8.5"
M. Hall, Methinks you are confusing the reverse rotation WATER PUMP on a serpentine setup with a reverse-cooling flow LTx series engine. If you are using your stock belt-driven accessories, all you need to do is use a water pump compatible with the original engine.
Tim sends
Tim sends
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
