1992 Z28, 5.0 automatic, secondary fan not working. need cooling fan switch part #
Car: 1992 camaro z28 5.0
Transmission: auto
Hello,
I'm new to the group. I am having a few issues. I just purchased a 1992 Z28, 5.0 automatic. My secondary fan is not working. The relay seems to be good. I swapped it with the primary and the primary works. When I place power on one if the pins of the A/C pressure switch, the fan spins (I think I have a bad pressure switch).I can’t get the radiator coolant switch (mine is under the throttle body) to activate the fan. I tried tying the 2 pins together and no luck, can someone point me in the right direction? All the wiring seems to be intact, no splices or funny stuff.
I have also been searching for and can’t find any updated part numbers for the "Fan cooling switch" mine is under the throttle body and is a 2 terminal type. I have a dual fan setup from factory. I need to know what the part numbers are for the colder switches, on/off temps. Any help will be appreciated.
Thanks again,
Thanks again,
Re: 1992 Z28, 5.0 automatic, secondary fan not working. need cooling fan switch part
AFAIK there are no fan switches under the TB, or that have 2 wires.
The thing you're messing with sounds more like the coolant temp sensor. Something else altogether. If its wires are yellow & black, that's what it is.
If you car has a fan switch, it's in the passenger side head, between the #6 & #8 spark plugs. Single pin, round. Should have a green w/ white stripe wire.
Transmission: auto
Thanks, the coolant temp sensor controls the gauge? i found my fan switch, its on the drivers side between 1 and 3. does this control my secondary fan? how do i test.
thanks,
thanks,
No. The temp gauge sending unit works the gauge. That's the thing between #1 & #3 spark plugs. The fan switch, if your car has one, is in the same hole, on the other head. The coolant temp sensor tells the ECM the coolant temp.
Transmission: auto
Thanks for the info. to test the fan switch, should i ground it and see if the fan works? do you know the part numbers for a colder switch?
thanks,
thanks,
Yes; grounding the wire should turn on the fan.
Don't know the part #, but just go to the store and ask for one for like a 85 GN.
Transmission: auto
i will give it a try and report back to the group.
thanks,
thanks,
