Electronic Fan Controller 70 Amp with Bluetooth Control
Old Jun 30, 2020 | 08:36 AM
kawaslut's Avatar
this is a really easy way to control your fans. it works great.
https://www.dakotadigital.com/index....od/prd1207.htm
Old Jun 30, 2020 | 08:53 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Electronic Fan Controller 70 Amp with Bluetooth Control
Is your thirdgen old enough that the ECM doesn't control the fan? I don't see much use for this in later thirdgens.
Old Jun 30, 2020 | 08:57 AM
kawaslut's Avatar
yes i can control the drivers side fan by changing the settings in the ecm but the other fan is controlled by a temp sender. I am just trying to share the info.
Old Jun 30, 2020 | 04:58 PM
Yeah kinda seems like an elegant solution in search of a problem to solve.
Old Jun 30, 2020 | 06:59 PM
most of us just tie the signal pair for the secondary relay to the primary fan relay. When the primary comes on it grounds the secondary fan relay.
though on my lt1 swap I have actual pcm controller primary and secondary fan outputs. They just happen to be bolt set the exact same.
breathment
Jun 17, 2024 10:04 PM
buckweber
Feb 3, 2019 02:18 PM
HEAVYMETAL
Mar 9, 2007 01:08 AM
75 wagon
May 22, 2006 09:15 AM
