A/C Compressor won’t stay engaged
Old Aug 17, 2020 | 09:38 PM
Goodolboy0404's Avatar
Car: 1987 Camaro IROC-Z w/ T-Tops
Transmission: Automatic
Axle/Gears: Factory 9 bolt w/ 2.77 ratio
My AC compressor is short cycling. It will turn on for a second and then turn off. Then back on and off again. The Freon level is saying “full” according to my gauge. I replaced the accumulator switch as well. Ideas??
Old Aug 17, 2020 | 09:48 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Re: A/C Compressor won’t stay engaged
Sounds like it is low on freon. I had a gauge that read full before, and bought a different one and it was actually low. It's possible that your gauge may be bad..
Old Aug 17, 2020 | 10:04 PM
that’s what I keep reading, but I don’t want TJ overcharge the system... is there anything else that would cause the short cycle?
Old Aug 18, 2020 | 02:49 PM
99.99% of the time it's because it's low on Freon. The other 0.01% it's because there isn't enough Freon.
BlackBird91
Jan 9, 2008 02:00 AM
Crazy 84 Z28
Jun 10, 2007 05:11 PM
RallySportin'
Jul 28, 2005 10:10 AM
