Evaporator housing insulation
Old Aug 19, 2020 | 03:14 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
Hey everybody! Long time-no see!
I wanted to ask the community if anyone knows where to get the foam insulation that goes inside the evaporator housing? Please see the picture below. Headers got a little too hot, too close. I’ve since clearanced the headers so they fit a lot better. No damage to housing. Thanks in advance!
the GTAman
Old Aug 19, 2020 | 03:58 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Evaporator housing insulation
Any closed cell foam should work there
https://www.amazon.com/s?k=1%2F8+closed+cell+foam+sheet&crid=3GV75O5SS5LIH&sprefix=1%2F8%22+closed+%2Caps%2C809&ref=nb_sb_ss_ac-a-p_2_11 https://www.amazon.com/s?k=1%2F8+closed+cell+foam+sheet&crid=3GV75O5SS5LIH&sprefix=1%2F8%22+closed+%2Caps%2C809&ref=nb_sb_ss_ac-a-p_2_11
You just don't want the foam to absorb water
Or you could get another box and swap it in or try to peel the foam out of the box and re-install
Old Aug 19, 2020 | 04:13 PM
It would help if you could find a way to rivet a heat shield to the outside right there; in some fashion that it would stand off a bit from the housing, and leave an air gap. I guess that would depend on how much space your exhaust leaves.
I'd want foam that had some sort of fire rating; it would SUCK if it got hot somehow and released toxic fumes into the air-handling system.
Old Aug 20, 2020 | 11:58 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I'm trying to find the other foam that goes along the front of the evaporator. I'm replacing my evaporator and the original part has the foam stuck/glued to it. I'd prefer to find replacement foam if possible.
Sonny Parks
Aug 24, 2019 07:04 PM
Txpo
Dec 4, 2014 09:21 PM
Slow87
Mar 24, 2012 05:54 PM
Randy82WS7
Feb 27, 2007 12:30 PM
82firebird
Jun 18, 2005 07:15 PM
