305 Fan Blades
Old Oct 18, 2020 | 04:36 AM
aussiesteve's Avatar
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
305 Fan Blades
Over the years i have run an aftermarket fixed blade fan but want to go back to the original setup,, clutch fan and GM blade type.
how many blades did the original blades have i see advertised 5 and 6
i dont need advise on what i should have all i need is an original setup.
i am not running A/C or any emissions.
Old Oct 18, 2020 | 08:30 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: 305 Fan Blades
Old Oct 18, 2020 | 02:44 PM
Re: 305 Fan Blades
Thank you for this Amazing set of specifications. And fast reply.
I was running a 400ci sbc +040 and down here in summer it can reach 118f
winter here is not a problem and while we get a dozen or so frosty mornings i have not seen snow in my lifetime.
I had a huge 4 core brass radiator built in 2001 until now and used a big 17 inch fixed blade fan that really done a number
i also ran a big 15 electric inch push fan on the front that cut in at 160f.
I just bought a nice 383 that dyno ran at 472hp and 431Tq
the engine builder i use reccomended me to put an original clutch fan back on as it will give me another 6 to 10 hp.
they arent running like a windmill all the time. and work perfect.
I just purchased a brand new Shroud / radiator Cowl and will order the fan and new clutch hub today.
The original was in my Shed but i cant find it since i moved.
Steve in Australia
Old Oct 18, 2020 | 02:57 PM
Jenkins's Avatar
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
Re: 305 Fan Blades
I live in a desert climate and love my original clutch fan set up. It gets just as hot here but even in daily traffic my engine remains around 180-190.
Old Oct 18, 2020 | 05:13 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 305 Fan Blades
original clutch fan blade for v8 Camaros was #14030071, a deep pitch 7 blade.
Old Oct 19, 2020 | 02:47 PM
Re: 305 Fan Blades
Dear Member
Thank you again.
just a quick note,, do these cars in a 5.0 carby car have a thermal clutch fan that cuts in and out on temperature the clutch picks up on
or is it a fixed 1:1 fan
apparently these cars had both.
my view is they were mainly thermal and what i need. as i will pick up HP over the fixed units like i was running.
steve in Australia
Old Oct 19, 2020 | 06:32 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Re: 305 Fan Blades
I think only non-AC stickshift 82-83 cars got the old 1950s type rigid 4 blade fan along with underdrive WP pulleys.By '84 seems they all had the clutch fan and overdrive pulleys.Certain non-AC cars also did not have a full fan shroud-just finger guard/upper support bracket.
fltche1
Jul 18, 2010 12:26 PM
Randy82WS7
May 14, 2006 08:14 PM
1987z28383
May 27, 2005 05:07 AM
jgallaway81
Sep 8, 2004 06:31 PM
brodyscamaro
Mar 28, 2003 12:06 PM
