Leaning Radiator and high filler neck
Old Jan 23, 2021 | 05:51 PM
CKRacing's Avatar
Car: 1984 Camaro
I tried to put in my Frostbite Ls specific radiator today but it didn’t fit with the stock cover obviously. So now I got a cover from a ‘71 on there and I trimmed the rubber pieces on the bottom. The radiator fits ok and isn’t loose. But it’s leaning quite a bit forward so I don’t know if this will be an issue when I swap in my LQ9. Also, the filler neck sits fairly high and I’m worried about it clearing the hood when I get it back on. I’ll leave some pics below. Any thoughts on this would be appreciated.
Collin
Old Jan 30, 2021 | 08:54 PM
MarineIROC's Avatar
Car: 1989 Camaro Z28
Leaning radiator
I ran into something similar w/ DeWitts Radiator interfering with points underneath the cross support - where the AC condenser insulators once were. My radiator is also slightly tilted. My Camaro is Auto so my problem (altho minor) was reconnecting transmission cooler hard lines. Instead of bending and messing with them, I removed them for a separate trans cooler with AN hose ends and nylon braided hose. As far as height, I used thin rubber insulator pads for the radiator feet which allowed me to reuse the stock radiator cover. I've had no issues.
Old Jul 14, 2022 | 11:29 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Re: Leaning Radiator and high filler neck
gt4373
Dec 30, 2020 10:27 PM
geoffhughes1986
Jul 11, 2016 01:47 AM
Blackjak
Nov 11, 2007 07:06 PM
Meatman
Exterior Parts for Sale
Sep 12, 2007 10:45 PM
