Cooling Fan Switch Wont Turn On (1990 RS Camaro 5.0)
Old May 15, 2021 | 12:25 AM
Rane90's Avatar
Car: 1990 Rs Camaro
Engine: v8 5.0
Transmission: Manual
My fan will only turn on with a/c, replaced temp sender, and thermostat, and the fan switch twice, the fan didnt come on when getting to activation temp, which is 205F for the new one I installed. Fan turns on with power probe to connector, so Im still assuming its the switch, so anyone know?
Old May 15, 2021 | 08:19 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Cooling Fan Switch Wont Turn On (1990 RS Camaro 5.0)
Double post !
Old May 15, 2021 | 10:35 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Do you have dual fan setup? Grab a wiring diagram and work methodically thru it to rule out stuff in the electrical path.
Old May 15, 2021 | 08:23 PM
Rane90's Avatar
Car: 1990 Rs Camaro
Engine: v8 5.0
I have a single fan, but the connector to the switch turns on the fan with a power probe so could it still be the wiring?
Old May 16, 2021 | 09:20 AM
LiquidBlue's Avatar
Transmission: MD8
The best thing you can do to get some help is find a wiring diagram for your setup and post it in this thread. then people can help you buy referencing the wiring diagram that you post.
Old May 16, 2021 | 12:46 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Disconnect the pigtail on the fan switch and ground it with key on and battery connected. If the fan goes on the wiring is good. If it doesn't go on you have a problem with the wire or connector that goes on the switch. If the fan does go on that would indicate the switch is either faulty or not able to ground with the head from too much teflon tape or compound. Check for continuity between the side of the switch and an engine ground which it needs to have to function.
You are replacing the fan switch on the passenger side, and not the temp sender on the driver side that is for the temp gauge, right?
Rane90
May 16, 2021 10:30 AM
JBeanie
Apr 12, 2014 07:11 AM
91camarodriver
Jun 7, 2009 02:16 PM
91black5spd
Mar 27, 2006 02:46 PM
TheBandit77
Jul 20, 2004 09:27 AM
