Higher Volume Heater/AC Blower??
Car: 92 RS
Engine: 3.1 V6
Is there such a thing as a high volume heater/AC blower motor and squirrel cage fan? It seems like mine just has had the volume needed for the last two or three times I have replaced it. It is time again as it is starting to rattle.
Thanks....
Thanks....
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Higher Volume Heater/AC Blower??
try to find an original GM motor in good working order instead of parts store china junk.If you can fabricate/modify,you could get a higher power blower motor for a truck cab or the like,make mounting plate,get suitable squirrel cage,and mount that in-many of those truck blower motors are ball bearing.Also check the evaporator(AC core) screen to make sure it is not plugged with airborne debris
