Cooling/heating hoses replace 350 TPI
Old Sep 6, 2021 | 06:17 AM
Simsalas's Avatar
Good day
I want to replace all the cooling and heating hoses on my 1988 Trans Am GTA TPI 350.
I found the upper and under cooling hose on Rockauto (Brand Continental). Now I am searching the different heating hoses without success. I only found a couple of them but not all that I need.
Can you help me with the part numbers?
1988 PONTIAC FIREBIRD 5.7L 350cid V8 Heizungsschlauch / Rohr | RockAuto
There is a kit on Summitracing but i prefer black hoses. Is there a black kit on the market available?
1988 PONTIAC FIREBIRD Continental Belts and Hoses 5002 Continental Super Elite Blue Hose Kits | Summit Racing
Thank you for an answer.
Simon
Old Sep 6, 2021 | 07:25 AM
Reddragon88gta's Avatar
Engine: 5.7 L98
Re: Cooling/heating hoses replace 350 TPI
These part numbers or descriptions should be what you are looking for seeing as how I have an 88’ GTA as well. The brand is Dayco and the hoses are all black. If you want to view this info in a better format just go to Dayco’s site and look up your car. Also if you need to replace your small oil cooler hoses near the filter just pull the old ones and bring to a parts store and they should be able to get you what you need. Another piece of advice is be patient or have a pro change that small hook shaped heater hose that comes off the heater core…access to that is a nightmare.
Application Description Part Number Footnote Routing Additional Info Serpentine Belt Main Drive 5060980
View Specifications, Brochure, Video Automatic Belt Tensioner
89213
Instructions, Video Tensioner Pulley
89007
Specifications Idler Pulley
89013
Specifications Premium OEM Replacement Balancer
PB2221N
Race Performance Balancer
PB2221SS
Street Performance Balancer
PB2221ST
Supercharger Performance Balancer
PB2221SC
Radiator Hose Lower 71131
Specifications Radiator Hose Upper 71203 Cut to Fit
Specifications Heater Hose Heater To Valve, w/A.C. 87701
Specifications Heater Hose Heater To Pipe-1 88353
Specifications Heater Hose Pipe To Valve, w/A.C. 88376
Specifications Heater Hose Heater To Pipe-2, w/o A.C. 87701
Specifications Heater Hose Valve To Throttle Body, w/A.C. 5/8 IN.
Heater Hose Pipe-1 To Radiator 3/4 IN.
Water Pump Heavy Duty DP9631 Heavy Duty option is for performance enhanced engines/severe duty applications
Water Pump Standard Duty DP963
Old Sep 8, 2021 | 10:01 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Here is a list of GM Part Nos. and diagram for your hoses less the two radiator hoses witch you already have
luckydog0_18
Jul 3, 2013 08:50 PM
joshwilson3
Jul 5, 2010 02:39 AM
I H8 WWD
Apr 23, 2009 04:44 PM
Project
Sep 5, 2005 11:15 PM
05kcilS
Aftermarket Product Review
Apr 16, 2003 04:21 PM
