Ok people. For those who replaced the small heater hose coming out of the fire wall. The aggravating hose shaped like a question mark. I am having an issue getting a clamp on the lower connection. It had a worm clamp on it and I had to cut it off to get the hose off. The hose was old and brittle so I decided to replace it.
I tried to put a tension clamp on there, but due to space issues I had trouble getting the one side to get low enough using needle nose vise grips. I actually have the pliers for tension clamps but it is too long for the limited space. Any words of wisdom getting a worm clamp back on and be able to tighten it? Take another stab at it with the tension clamp?
Thanks to all that have been here before.
REIM
REIM
TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Positive Feedback100
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,156 Times in 755 Posts
1/4 drive tools with extensions, Ujoints and ratchet are a big help for the worm gear clamp.
For the spring type, if you don't have the tool, you are missing out.
Ok. I have the other type of spring clamp tool. Let me get this one and give it a go. Thanks TTOP.
mantaguy
close
- Join DateNov 2010
- LocationMantua NJ
- iTrader Feedback Score(5)
- Car1 Owner 1986 TA with a WS6 package
- Engine5.0 EFI
- TransmissionTHM700R4
- Axle/Gears277 Posi Speedo
- Liked:85 Times in 74 Posts
That DREADFUL CLAMP
