Fan size?
Old Feb 1, 2022 | 08:45 AM
5.0ta's Avatar
Car: '86 Trans Am
Engine: 5.0L TPI
Axle/Gears: 3.27 posi/disc
Fan size?
I need to replace the electric fan...what's the biggest fan (dimensionally) that will fit a factory radiator?...1986 Trams Am TPI 305.
Old Feb 1, 2022 | 01:48 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Fan size?
Why not just replace the radiator fan motor? You can get those pretty cheap
Old Feb 1, 2022 | 02:08 PM
5.0ta's Avatar
Car: '86 Trans Am
Engine: 5.0L TPI
Re: Fan size?
[QUOTE=1989karr;6455728]Why not just replace the radiator fan motor? You can get those pretty cheap[/QUOTE
I'm wanting something with a high CFM and low amp draw.
Old Feb 1, 2022 | 05:38 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Re: Fan size?
[QUOTE=5.0ta;6455732]
You Could consider LS1 fans but with TPI fan motors. as the LS fans suck juice. But youd need to do a little extra wiring.
But I have seen people shove in I believe up to 16 inch fans
Old Feb 2, 2022 | 06:13 PM
jcat's Avatar
Car: 96 Impala 84 berlinetta
Transmission: 4speed auto
Re: Fan size?
put the correct fan motor with the correct amp load. if you want a bigger fan motor change the alternator around 100 amp spec..high power motor look up the amps higher on the old motor amps. I use a dc amp meter clamp ..
Old Feb 5, 2022 | 12:47 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Fan size?
16" yes (on the eng side). I put a Spal unit in using the stock mounting points.
327???
Oct 5, 2005 05:34 PM
z28monster
Apr 7, 2005 10:50 PM
cali92RS
Southern California Area
Oct 23, 2004 08:07 PM
TPI86TA
May 13, 2004 08:10 PM
Apeiron
Nov 17, 2002 08:32 PM
