can you put a flex fan on an engine that has an electric fan...
Old Apr 4, 2005 | 11:33 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
hey guys i own an 86 iroc z it has a 5.0 tpi engine and before the deer i hit it had a working electric fan..... well i have been driving it through the winter to get to work with out a fan on it and now that the weather is getting warmer.... it is getting way to hot to be able to drive any more with out a fan..... id liek to put a flex fan on it if possible but wasnt sure if i was able to put one on it like you would see on an older v 8...
is this a simple bolt on ????
Old Apr 5, 2005 | 12:54 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you have a V-belt setup, you could remove the electric fan and shroud, and install a mechanical fan and shroud. A stock type clutch-fan would be a better choice than a flex fan though.
Old Apr 7, 2005 | 02:50 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
im running a flex fan with a 1" spacer. stock shroud. no problems yet. my motor has v belts. easy change and alot less money than new electric fan.
Old Apr 7, 2005 | 10:50 PM
z28monster's Avatar
Car: 86 IROC-Z
when i went to the store and held up a 17 inch flex fan to ware it would bolt up to the engine it seemed like it wouldnt fit.... the tpi intake was int he way of the blades..... looked like the blades were goign to def hit the MAF sensor..... can i see pics of a fan installed on a tpi engine.... to show me it will realy work....
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
mhatfield 14
Oct 24, 2015 07:48 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
