Plastic part under motor to sent air up in radiador
Old Oct 30, 2022 | 09:09 AM
SCOODY's Avatar
Car: Z28 / 1984
Engine: 5L
Hi,
The plastic part under the motor in front, that makes the air going up in front of radiator (helps fresh the motor temerature) in broken.
I'm searching for it's name , part / number on rockauto .... Any help appreciated !
Best Regards
Old Oct 30, 2022 | 09:49 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Plastic part under motor to sent air up in radiador
Rock Auto Doesn't Have It
Old Oct 30, 2022 | 11:09 AM
SCOODY's Avatar
Car: Z28 / 1984
Engine: 5L
Hi,
Thank's for your reply think this part is missing on my Z28 1984 ! i will order it !
I was talking about that one : ( see picture)
Old Oct 30, 2022 | 11:44 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
It's called a deflector, commonly called air dam
Old Oct 30, 2022 | 12:32 PM
Air deflector or air dam
Don't think you can get a new one anymore
You can make one pretty easily out of a mud flap for a big truck (cut off a strip about 6 - 7" wide) and a piece of aluminum angle. Make it long enough to go completely from one side to the other of the place it bolts to up under there, or maybe an inch or so more on each side. Bolt the angle to the car and the rubber strip to the angle. It's stiff enough to hold its shape while normally driving but will bend out of the way harmlessly when you bump it into a parking lot curb or whatever.
Old Oct 31, 2022 | 05:05 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Hawks Third Gen have them
Old Nov 1, 2022 | 08:00 AM
jcrocker8829's Avatar
Ebay has quite a few reproduction air dams. I've got one on my 84'.
he ya go.
Old Nov 1, 2022 | 03:06 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
i go the one from ebay for the firebird... fits perfect.
im pretty sure its the same unit sold be hawks but for a bit cheaper
Kevman
Nov 12, 2007 04:29 PM
ajk511
Interior Parts Wanted
Oct 22, 2006 02:37 PM
Josh91Bird
Mar 5, 2003 08:41 PM
Trippinfelix
May 16, 2002 11:54 PM
91RamAir Formula
Oct 16, 2001 04:39 PM
