Hawks replacement trunk motor
Old Nov 11, 2007 | 09:56 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey guys, a while back I broke my trunk motor, so I put down 90$ on a new Hawk's replacement one. It's got the motor, and the plastic bracket attached. I have no idea how to put this on, do I have to tap the plastic, in order to get screws in? And does everything mount up like it should? Thanks, KP.
Old Nov 11, 2007 | 10:35 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Re: Hawks replacement trunk motor
Post pics so we can see. I am not sure about "tap the plastic". What plastic? All of the motors I have replaced have been used so they were a direct bolt in. It should be pretty easy - 15 tops.
Old Nov 12, 2007 | 12:16 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
No need to tap the holes. The screws are self-tapping. You can follow the Tech Article on TGO I wrote to see how to re-assemble the pull-down unit using the new motor you purchased. Was the new motor reinforced with aluminum & epoxy? If so I know where they bought it.
Lon Salgren
Top-Down Solutions
Old Nov 12, 2007 | 03:43 PM
Kevman's Avatar
Engine: 2004 LQ4
I got it all together, put it in and of all things, it doesn't work... I think a fuse is blown, but not sure. Is there a fuse under the dash? I tested the one on the wire to the motor, and i was getting 0 ohms, so I think it's pooched.
Old Nov 12, 2007 | 03:50 PM
lonsal's Avatar
Unplug the red/white stripe wire from the blue wire and test it for +12v. The fuse on Firebirds is not in the fuse panel, but is in a separate fuse holder that should be attached to the outside of the fuse box.
Lon
Old Nov 12, 2007 | 04:17 PM
Kevman's Avatar
Engine: 2004 LQ4
Thanks Lon, I'll check that in a bit.
Old Nov 12, 2007 | 04:29 PM
Kevman's Avatar
Engine: 2004 LQ4
11.8 volts at the blue wire. Still nothing working... KP
1992rs/ss
16
Jan 28, 2016 09:58 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Elliswon
Aug 10, 2015 12:33 PM
drathaar907
Aug 6, 2015 04:20 PM
Leggman1
Aug 6, 2015 04:15 AM
