1992 camaro 3.v6 lower coolant fan switch
Old Jan 10, 2023 | 03:34 PM
9169 camaro's Avatar
Car: 1992 rs
Engine: 3.1
Transmission: 5 speed
I am looking for the part # for the coolant sensor/switch to turn on the single fan on 1992 camaro rs 3.1v6. I have changed many of these on tpi cars with the single wire hypertech fan switches. But it looks like the v6 is a 2 wire ,close to the thermostat housing. Is this the correct sensor/switch to change out? Any help is appreciated thanks
Old Jan 10, 2023 | 06:03 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: 1992 camaro 3.v6 lower coolant fan switch
the 3.1 doesnt have a fan switch but instead uses the ECM temp signal to turn the fan on. I think it gets its info from that switch you mentioned though
Old Jan 16, 2023 | 08:50 AM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
https://www.rockauto.com/en/catalog/....1l+v6,1251829
I use Rock Auto all the time for part numbers. They have cross reference, just hit the "INFO" button on the item and check "OEM / Interchange Numbers:"
Old Jan 16, 2023 | 04:36 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
That part is generally referred to as the CTS as in coolant temperature sensor. Gives input to the computer for many functions
Old Jan 19, 2023 | 08:34 AM
Car: 1992 rs
Engine: 3.1
Thanks . I was hoping to find one that would change the temp that the fan would come on sooner. But doesnt look like it can be done.
Old Jan 19, 2023 | 11:17 AM
1989karr's Avatar
Engine: 3.4 / 5.0
For the 3.1, I think you have to have the chip / PROM in the ECM reprogrammed in order to change that.
johnnyboy6961
Jan 20, 2022 02:47 PM
bessie
Sep 14, 2018 07:08 AM
svanky10
Aug 13, 2005 10:26 PM
Camaro_nut
May 23, 2003 06:58 AM
anesthes
Aug 14, 2001 11:00 PM
