coolant and oil mixed ?
Old Jul 20, 2023 | 02:10 PM
keis's Avatar
1990 l98, coolant and radiator flushed a month ago, reservoir now looks like this:
reservoir^^
Old Jul 20, 2023 | 02:30 PM
ACebell's Avatar
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
Re: coolant and oil mixed ?
Oil and water don't mix! The first pic is the clean(ish) coolant? and the second is the chocolate milk? If that is the case, then you have won the blown head gasket award! or worse a crack in the block.
Time to dump the oil out of the oil pan and see if it matches the chocolate milk in the overflow tank.
Old Jul 20, 2023 | 06:25 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Do you have the oil cooler on your car? it is between the filter and the block-engine coolant is plumbed to it, and the two liquids could mix if something is wrong with the cooler.
Old Jul 21, 2023 | 10:16 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
A/T cooler leak into rad or head gasket shot
Denis.V
Nov 30, 2004 06:02 AM
NHRATA01
Aug 28, 2003 08:41 PM
Acidtalons
Aug 10, 2003 01:03 AM
Bill 91RS
Jun 3, 2002 07:00 AM
BrianB
Sep 20, 2001 10:19 AM
