thermostat housing
Old Oct 24, 2023 | 12:47 PM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
thermostat housing
I have a Edelbrock performer intake. Does anybody know where I can find a thermostat housing with the bolt holes on each side like the old sbc with a 1 5/16 dia. neck? Part number or make/model of car? Any help is appreciated. What did you do on your swap? Get a different hose? Which one?
Old Oct 27, 2023 | 05:30 PM
vf750rider's Avatar
Car: 1992 Teal RS
Engine: 350 Carbed
Axle/Gears: 4th Gen Rear 3.42
Re: thermostat housing
Google "sbc thermostat housing" and you'll see that every local parts store has them on the shelf.
Old Oct 27, 2023 | 06:31 PM
BBCSwap's Avatar
I have not found one that has a 1 5/16 neck.
Old Oct 27, 2023 | 07:44 PM
vf750rider's Avatar
Car: 1992 Teal RS
Engine: 350 Carbed
I shouldn't be looking when I'm tired! Now that I'm tired AND curious ... where does the 1 5/16" come from? All the hoses I see for 3rd gens are 1.5" inside dia., and that's all I ever remember using on most all sbc I've dealt with. So I'm wondering what hose you have?
Old Oct 27, 2023 | 08:04 PM
BBCSwap's Avatar
The 350 TPI that I pulled out of the car has a 1 5/16" outside diameter thermostat housing water neck. I'm doing a engine swap so I wanted a thermostat housing with that same diameter so I could use the same radiator hose. I have a 1 1/2" water neck & hose on the way.
BBCSwap
Oct 24, 2023 12:34 PM
Stev3n
Jun 11, 2020 03:32 PM
itsMikey
Sep 3, 2010 06:54 PM
87350IROC
May 12, 2008 02:39 PM
Tom91Bird
Jan 5, 2005 03:32 PM
