92 305ci fan will not come on
Car: 1992 Z28 1LE manual
Transmission: 5 speed manual
I have run direct power to the fan. It comes on. I have found the green and white wire at the relay. Under the car, I found there was no wire hooked to the fan switch. Couldn't find the wire dangling anywhere. It's like it was never there. I spliced into that green and white wire at the relay. I grounded the spliced in wire and the fan comes on. So, I ran a wire from the switch to the relay. Fan does not come on. I replaced the fan switch. Hooked my wire to it and fan still does not come on. What that the heck? Perhaps I should just put a switch in the cockpit and try to remember to switch it on? Any thoughts appreciated.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 92 305ci fan will not come on
Check the switch is making a good ground connection through the threaded hole in the head-no thread tape
Red85TA
Jul 25, 2000 06:44 PM
