Cooling Fan Clutch
Old May 31, 2024 | 10:00 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Cooling Fan Clutch
1984 T/A 305 - 150 hp + QJ. Does anyone know at what temp the original fan clutch kicks into operation?
Old May 31, 2024 | 12:44 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Cooling Fan Clutch
Most GM clutches will fully engage when the air temp hits ~210F. The will progressively tighten up starting around 140F. Air temp, not engine temp. With the ac on, it will engage at a lower coolant temp because of the added condenser heat.
Old May 31, 2024 | 02:14 PM
72buickgs's Avatar
Car: 1984 Trans AM
Tkx Fast355. I sort of figured that. U answered my question.
Old Jun 1, 2024 | 10:31 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
I discovered mine engages full at around 230* coolant temp: was climbing a steep,long grade in hot weather when temp started creeping up...got a little over 230 when a roar was heard underhood and temp shot right back down to 190 and fan noise subsided HD fan clutch from a cop car '83 impala.
SuperHawk996xx
Jul 15, 2012 10:05 PM
gray89vert
Jul 25, 2007 11:55 AM
Ian'sTA
Apr 11, 2007 09:39 AM
Bobbyz
Jul 16, 2003 03:10 PM
