White smoke
Old Sep 9, 2024 | 06:41 AM
2016eversince's Avatar
Car: 91 Trans Am GTA
Transmission: Auto 4-Speed
White smoke
Just changed water pump after finding a massive coolant leak. No overheating so far and not a major leak observed but I drove to work, parked, and noticed white smoke coming from the engine compartment from the oil reservoir ... I dont know if it's coolant, and if it is... why??? If its not overheating or leaking then???
Old Sep 9, 2024 | 07:45 AM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: White smoke
What's your oil look like?
Old Sep 9, 2024 | 08:09 AM
Re: White smoke
I checked it recently, within a week ago, and its maple syrup brown... doesn't need topped off, maybe excess got lost while filling coolant a while ago and thats whats burning?
Old Sep 9, 2024 | 10:02 AM
Car: 82 TA
Re: White smoke
It could be just burning off. Make sure you have cooling system pressure.
Old Sep 9, 2024 | 10:24 AM
Re: White smoke
Thank you. I know i burn oil but its never smoked in the engine bay only in the exhaust.
Old Sep 9, 2024 | 10:51 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: White smoke
What is the "oil reservoir"? Is white smoke coming out of the dipstick tube? Oil-fill hole? The oil pan is the "oil reservoir", IDK how white smoke would come from the pan....
Old Sep 9, 2024 | 11:23 AM
Re: White smoke
oil fill hole. sorry forgot to clarify specifics.
Old Sep 9, 2024 | 11:35 AM
Engine: LT1, L400
Re: White smoke
That sounds like blow by. I'd start with a leak down test.
Old Sep 9, 2024 | 11:50 AM
Re: White smoke
if that is the issue, it would not surprise me... noticed a lot less fuel efficiency lately. like, burning half a tank within a day of normal driving.
Old Sep 11, 2024 | 10:23 PM
Re: White smoke
Here's some pictures of the smoke coming through the hood gap... Some things to note:
-i'm running to 220 after 10 minutes
-the coolant i used is Fram 50/50 green, but i'm led to believe that it has a lower heat capacity than desirable, as straight water for example has a specific heat of 4.2 J/g-K whereas 50/50 antifreeze seems to have a specific heat of 3.5J/g-k... meaning to say that it gets hotter more quickly...
-no coolant leaks on the outside of the car
-no check engine light
-the steam/smoke is only visible in the morning when it’s cold, and i don't notice it at all when i go home for the day...
Old Sep 12, 2024 | 08:36 AM
Engine: LT1, L400
Re: White smoke
A pic of where it's coming out of the engine would be more helpful. What's the smoke smell like?
Old Sep 12, 2024 | 08:40 PM
Re: White smoke
Yikes on bikes! Scrapping this car asap. (Kidding…) The coolant on the left is straight from the bottle and the coolant on the right was taken from the radiator using a syringe. Note that the coolant on the right is no more than a week old…
Old Sep 12, 2024 | 09:26 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Re: White smoke
A 50/50 mix of water/coolant isn't going to cause cooling issues. That's how the car is designed to run. Shouldn't be at 220 driving down the road. More like 190ish.
The smoke could be from a coolant leak that's just burning off before it has a chance to hit the ground. But the discoloration definitely isn't normal and shouldn't be caused by a leak. Also, white smoke coming from the oil fill sounds like water making it's way into the oil. Usually that's a bad head gasket or cracked head.
Is there white smoke coming from the exhaust also?
Old Sep 13, 2024 | 08:44 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Re: White smoke
how about a leaking frost plug? Been there & had that.
mjc928
Jun 17, 2010 11:09 AM
bigwhisgta88
Members Firebirds
May 8, 2009 01:57 PM
fearfactory17
Mar 1, 2005 05:13 PM
Iroc n roll
Sep 9, 2004 07:57 PM
ryguy85
Aug 11, 2004 01:07 AM
