Where can I find this molded hose on the coolant bypass valve assembly?
Old Dec 4, 2024 | 10:46 AM
t/adreams's Avatar
Car: '91 Trans Am
Engine: 350 Blueprint Engines Cruiser
Transmission: TKX 5 speed
Axle/Gears: 3:42
Hi all! I'm looking for a part number, name, or place to buy a replacement hose for "B" in the photo.
Old Dec 5, 2024 | 06:05 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Re: Where can I find this molded hose on the coolant bypass valve assembly?
Is this it? If Auto Zone has it then other parts stores should have it to.
https://www.autozone.com/cooling-hea...8376/10276_0_0
Go to Auto Zone and enter your car then search "heater hose" and it should prompt all the heater hoses for your car.
Old Dec 5, 2024 | 08:27 AM
t/adreams's Avatar
Car: '91 Trans Am
Axle/Gears: 3:42
Thank you! I was pulling whats left of my hair out trying to find it!
Old Dec 5, 2024 | 08:56 AM
t/adreams's Avatar
Car: '91 Trans Am
Axle/Gears: 3:42
For anyone else looking for this hose:
Description
Molded Heater Hose, Dayco
Specifications
Color: Black Contains Heat Shield: N Contains Protective Sleeve: N End 1 Inside Diameter: 3/4 End 2 Inside Diameter: 3/4 Hose Type: Single I.D. Hose Material: EPDM SAE Specification: SAE J20R3 Class D-1, SAE J1684 Type EC Trunk Height: 10
Interchange
  • ACDelco: 14307S
  • ACDelco: 16155M
  • CARQUEST: 19632
  • CARQUEST: 19727
  • Duralast: C88376
  • Ford: F5AH-18C266-AB
  • Ford: F6AZ-18472-A
  • Ford: F8AH-18K579-AC
  • Ford: F8AZ-18472-AA
  • Ford: F8VH-181K579AC
  • Ford: F8VH-18K579-AB
  • Ford: F8VH-18K579-AC
  • Ford: 1W1H-18K579-AA
  • Ford: 1W7H-18K579-AB
  • Freshstart: 4347
  • Gates: 19727
  • Gates: 19632
  • Goodyear: 63083
  • NAPA: 11632
  • NAPA: 11727
  • V&W: 304376
Fitment
  • 1987-1992 Chevrolet Camaro Position: Pipe To Valve Note: w/A.C.
  • 1987-1992 Pontiac Firebird Position: Pipe To Valve Note: w/A.C.
  • 1991-1993 Lincoln Town Car Position: Heater To Pipe Note: w/o Auto Temp. Control
  • 1992-1993 Ford Crown Victoria Position: Heater To Pipe Note: w/A.C., w/o Auto Temp. Control
  • 1992-1993 Mercury Grand Marquis Position: Heater To Intake Manifold Note: w/o Auto Temp. Control
  • 1994 Ford Crown Victoria Position: Heater To Engine Note: w/o Auto Temp. Control, Curved
  • 1994 Mercury Grand Marquis Position: Heater To Engine Note: w/o Auto Temp. Control, Curved
  • 1995-1997 Ford Crown Victoria Position: Engine To Heater Note: w/o Auto Temp. Control
  • 1995-1997 Mercury Grand Marquis Position: Engine To Heater Note: w/o Auto Temp. Control
  • 1995-1998 Nissan 240SX Position: Valve To Pipe
  • 1996-1997 Lincoln Town Car Position: Heater Inlet Note: w/Auto Temp. Control
  • 1998-2000 Ford Crown Victoria Position: Intake Manifold To Heater
  • 1998-2003 Lincoln Town Car Position: Intake Manifold To Heater
  • 1998 Mercury Grand Marquis Position: Intake Manifold To Heater
  • 2005-2008 Chrysler 300 Position: Tee To Pipe Note: Hose Must Be Cut On Both Ends
  • 2005-2008 Dodge Magnum Position: Tee To Pipe Note: Hose Must Be Cut On Both Ends
  • 2006-2008 Dodge Charger Position: Tee To Pipe Note: Hose Must Be Cut On Both Ends
  • 2008 Dodge Charger Position: Tee To Pipe
Old Dec 6, 2024 | 08:58 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
y/adreams. That is a great crossover list. Tkx.
92GTA
Sep 13, 2015 04:35 PM
lakeport
Jul 29, 2014 02:32 PM
rob2000gt
Oct 23, 2012 10:56 PM
formula forever
Sep 20, 2005 10:54 AM
NHRATA01
Aug 12, 2003 09:47 AM
