Best way to get a look at the AC Evaporator
My AC is leaking. I put some dye in and don't really see anything under the UV light under the hood. I would like to check the evaporator, but it seems like a huge hassel to remove. Is there an easy way I can just see it to shine the UV light on it? Myabe under the dash? I know the heater core is there, is the evaporator right behind it?
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: Best way to get a look at the AC Evaporator
3 bolts in the interior, just under the edge of the carpet; 4 IIRC on the engine side, mostly across the top and toward the engine. All 13mm IIRC butt a couple might be 10.
I recall needing an evap housing once. Junkyard closed at 5. I got there at 4:55, went out and found a car, and was standing at the counter with one before they shut down at 5. I defecate you not.
Car: 1983 G20 Chevy
Transmission: 4L60
The condenser is what needs to be changed with a R134a conversion to restore proper cooling. Install the largest parallel flow that can fit.
Car: 1983 G20 Chevy
Transmission: 4L60
It is not. Comes RIGHT out.
I put an evaporator core in both a Camaro and Transam over the years.
Car: 1983 G20 Chevy
Transmission: 4L60
I will also add you can pickup a functional refrigerant sniffer that works very well for under $100. Just be warned they pickup hydrocarbons from the exhaust or evaporating ac flush too. Figured that out using one the other day to locate a small leak in a 2003 Avalanche which was as I assumed the high side service port. The sniffer figured out that truck has an exhaust leak from a broken manifold bolt that you can not even hear. It is a LS, go figure they all break manifold bolts and always the ones up against and burried under the firewall.
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I wuld think you can pop off the 7?? mm bolts and I think 10mm bolts that hold the top of the evaporator case on, pry it gently open and shine the light in there
