removing my AC and heater core?
Car: 1984 Camaro SC
Engine: 305 V8, LG4. For now...
Transmission: 700R4, for now...
Axle/Gears: ???
SO guys i was thinking of removing my ac to save weight. but when i was in school, i was told that when you use ur heater the AC turns on too, because the evaporater removes the moister from the air (which i no is true)
My question is, does it make that big of a difference? like if i remove the ac, and keep the heater core will my defrost work anymore? or will there be too much moisture in the air for the defrost to work?
and my camaro is my daily driver, so i think i need the defrost. just today it kept fogging up cause it was cold n rainy
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: removing my AC and heater core?
I bought my car with the AC removed and the heat and defrost worked just fine.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Turning on the A/C to dry the air with the defroster is just a convenience, you can live fine without it.
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
Think of it this way, They did make Camaros/Firebirds with No A/C and they still had defrost and heat.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
my 86 truck came from the factory with no ac, just heat. youll be fine with no ac. but if you want defrost and heat, leave the heater core intact.
Car: 91 Camaro RS
its in the dash. you have to remove the passenger side underdash piece, then take out some screws on the plastic cover piece to get access to it, there's tons of threads on exactly how to replace the heater core (or just remove it). but theres really no sense to remove it completely.
Car: 1984 Camaro SC
Axle/Gears: ???
its how the ac works, the evaporator in the ac is wat cools the air u feel in the car (basicly). u ever knotice there is a pool of water under ur car when u use the ac? it from the evaporator, one thing it does is remove moisture from the air.
but thanks for the input guys. Im still wondering if i should remove it. lol its very tempting to take out all that weight sence i have a lame 305. anyone know how much the entire ac system weights?
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
It shouldn't weigh that much. The heaviest part is the compressor. Everything else is IIRC, aluminum. Just remove the compressor. Think about it this way. If you fill up the tank to go to the races, your adding almost 100 pounds of weight. 1 gallon weights about 8 pounds. Multiple 8 by the capacity of the fuel tank (approx 12 gallons) and you get 96 pounds. So by removing the compressor, you'll save about 5-10 pounds.
Engine: 383 Carb
Transmission: 4L60
About 15 lbs from the compressor alone, 10 for the condenser. Maybe 30-35 lbs from the whole system.
Engine: 383 Carb
Transmission: 4L60
There have been more difficult things done to save less weight.
I bet. Removing parts to replace with fiberglass panels, the hood, removing all seats ecxept the drivers, no dashboard, gutting out the engine bay. The list goes on and on.
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
There is no way I would remove my AC from my daily driver just to save a bit of weight.
I just dont see it worth any noticeable gain anywhere. I will bet that some hot day while you are sitting in traffic you will wish you still had AC.
Just my opinion. Weight isnt everything. Especially not in a daily driver. If this was a race car then go for it. I just dont see why people remove it.
Car: 91 Camaro RS
id rather add hp than remove the ac....
Car: 1986 IROC-Z
I live in So. Fla and it gets HOT down here. I would not remove my A/C from my car. My buddy made that mistake about 5 years ago and regrets ever doing it.
Car: 1984 Camaro SC
Axle/Gears: ???
And when u make as little hp as i do then all the wieght saving really counts lol my car had 150 hp 27 YEARS ago, lol not alot then even less now.
Well the heater weighs about 5lbs, so remove the AC if it doesn't work, but you'll miss the heater core when your shivering and wiping the condensation off the inside of your windshield some chilly morning.
Don't ask yourself if you can live without it, ask yourself if it will make you want to drive your car less. IE, on that cold morning, when you feel like driving your camaro to work, and you step outside and realize how cold it is, and you decide to drive your boring nissan in instead. To me that isn't worth it to remove the heater.
I just finished hooking up the heater lines in my car for that very reason! It makes it so I can enjoy driving my car more. The next thing will be a bigger muffler, it will prolly rob a little power, but my ears won't be ringing after a half hour cruise, and I'll like driving it more.
well first off the compressor had been shot sence the day i got the car 3 years ago, so its never worked sence ive had it. and i used to live in so cal, and it got ****ing hot here and i lived lol. but more to my point, i want to save weight cause it cost less to remove an sc system then to fix it.
I recently removed my complete HVAC system from my car and weighed it. All components, including the compressor and brackets, condenser, evaporator, receiver/drier, lines, R12, heater hoses, coolant, bolts, HVAC case (both sides), wiring, etc ended up weighing 80lbs.
No way would I remove the heater system from a daily driver.
Car: 1984 Camaro SC
Axle/Gears: ???
Car: 1984 Camaro SC
Axle/Gears: ???
lol i lived near san bernardino, so still pretty south if u ask me, especially sence i was born and raised in green bay wisconsin lol
Car: 91 Camaro RS
if youre leaving the heat, then you have to leave the box on the firewall (houses the blower), or get an ac delete box.
Car: 1986 IROC-Z
Maybe if I were concerned bout mine being strictly for racing and was worried bout times, I might concider it, but being its just for fun and comfort I will keep it. It was broken just before the beginning of summer so I had the compressor removed and resealed and hoses all redone and recharged. Cools as good as these cars can do for the year. lol
Car: 1984 Camaro SC
Axle/Gears: ???
Car: 91 Camaro RS
they pop up in the classified on here every once and a while too. usually from someone who got tired of not having ac...
Car: 1984 Camaro SC
Axle/Gears: ???
can i remove the evaporator without having to remove the whole ac plemtum assy?
Car: 87' Firebird Formula
hello, not thread jacking, just looking for so quick and easy assistance on the same subject...ive deleted ALL my ac except the part beside my heater core..can i remove that without using a ac delete heater box. ive seen pictures where people just welded the hole closed but i still need my heat. it doesnt get UNBEARABLY hot here but i do need my defrost and heat. like i said, not thread jacking, just need some quick help. i even got my hood up and tools ready lol
Car: 1984 Camaro SC
Axle/Gears: ???
Car: 91 Camaro RS
you can just weld the firewall yes, but only if you want no form of selectable air blowing in the cabin. meaning no heat, no ac, no defrost, no nothing. at that point you could remove all the air ducting from the dash too. youll also have to redo the coolant hoses to delete the section that goes to the heater core.
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
does anyone make any aftermarket non ac heater boxes besides acdelete.com ?
Car: '86 Iroc-Z, '98 A4 Quattro
Engine: 5.0 TPI
is there an article on how to remove the core? i found a big puddle on the floor last week
It's pretty straightforward. Pull the passenger side hush panel and you should be able to get at the heater core access panel pretty easy. Been years since I did it, but it didn't take longer than half an hour
