1984 Trans Am lower rubber radiator supports
Old Aug 23, 2025 | 07:06 AM
TA392's Avatar
Anyone have a picture or know exactly where the lower radiator rubber supports are supposed to be located on the bottom frame ? There are two hole where the rubber nipples on could go on the lower support. When I pulled the old rad they fell off.
Old Aug 23, 2025 | 05:58 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: 1984 Trans Am lower rubber radiator supports
They go right under the edges of the rad where it meets the tank. Those nipples pull through the holes on the lower tray. Put them on the rad and the rad will locate them for you
Old Aug 24, 2025 | 08:28 AM
TA392's Avatar
Thanks for the reply, Yes I know the rubbers go on the tank seams and the nipples go through the holes. My bottom tray/rad support has two holes in line with each other on both sides, one closer to the engine and one closer to the nose. I put the new rad in and it seems to be 3/4 inch higher that the original when I put the top support on, so Im thinking I may have them in the wrong holes. The tranny lines make it a pain to easily adjust the rad.
inNEEDofPAINT
Aug 5, 2009 05:05 PM
sam356
Nov 10, 2006 12:48 PM
1995firebird
Sep 5, 2005 02:42 PM
