Help finding a A/C component.
Old Nov 8, 2025 | 09:41 PM
92z23's Avatar
Car: 1991 RS
Engine: L03 305
I’ve got a 1991 Camaro RS. Just finished up A/C overhaul. High side pressure line for the a/c snapped off the end where it connects to the condenser. Anywhere to find this line? I’ve looked all over with no luck.
Old Nov 9, 2025 | 05:56 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Re: Help finding a A/C component.
https://www.rockauto.com/en/moreinfo...uzhcHGxg%3D%3D
Old Nov 9, 2025 | 06:52 PM
92z23's Avatar
Car: 1991 RS
Engine: L03 305
I’ve got that one, it’s the hard line that runs down the frame on the right side down to the condenser. Number 5 on this schematic. Apparently it’s a real pain to find. Anyone got one by chance?
Old Nov 10, 2025 | 05:51 AM
BBCSwap's Avatar
Maybe a salvage yard.
Old Nov 10, 2025 | 06:36 AM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Pm sent.
Old Nov 10, 2025 | 06:45 AM
Pocket's Avatar
Car: 91 Trans Am
You may have better luck making a new line from soft hose components
#8 fitting to #6 hose 90* near the box for the orificetube
Metric pressure port tee for the fan switch
#6 hose end for the condenser
Basic #6 hose, standard or RB whichever your fittings match
Those small hardlines are getting scarce as more and more break
Old Nov 17, 2025 | 02:29 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I believe classic auto air used to make it,.. but i heard it was discontinued.
it looks like only the older unit is available which you can use but you'd need the older evaporator.
82-88 Camaro/Firebird A/C Liquid Line | Classic Auto Air
The best you can do for the 89 up line would be to get a used unit.
19irocz85
Apr 30, 2015 08:27 PM
BlueZee28
Oct 7, 2014 08:50 PM
RedWind
Feb 3, 2008 06:14 PM
shaggy56
Aug 27, 2004 08:13 PM
Makai
Apr 30, 2003 12:44 PM
