Duel Fan Relay Location
Old Nov 12, 2025 | 08:50 AM
upstateRich's Avatar
Car: 1989 Firebird
Engine: 2001 5.7 LS1
Where are you guys mounting a relay for a new duel radiator fan setup
Old Nov 12, 2025 | 10:29 AM
skinny z's Avatar
Re: Duel Fan Relay Location
Two locations come to mind. One Camaro I had placed the relay on the rad core support low on the passenger side.
My current Camaro has the relays located just to the left side (driver's side) of the brake booster.
There are advantages to both.
And FTR, two fans equals two relays. Or should.
Old Nov 12, 2025 | 11:32 AM
Car: 1989 Firebird
I was thinking of a similar area on the passenger side with the battery on that side and the ECU. I ordered a duel relay that should be in today
Thanks Rich
Old Nov 13, 2025 | 11:23 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Passenger side just above the cruise control unit. Added a nutsert
Old Nov 13, 2025 | 11:57 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
If 89 Firebird is anything like a 90, pretty sure its on the firewall as described above. There is a bracket there, which holds about 3 relays, had to put my car in storage while old garage got demolished, so I cant check.
Old Nov 13, 2025 | 07:27 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Stock should I believe have one at the radiator core support on the passenger side by the air filter housing, and the second fan has the relay close to the firewall on the driver side by the other relays.
if you're installing an all new wiring / system then I'd consider putting it maybe up by the firewall where the stock second relay would be. Easy access / shouldn't get as hot up there.
Old Nov 14, 2025 | 04:46 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44, Tru Trac, 3:73 gears
SPAL dual 12 inch fans
BUSS fuse and relay block on driver side strut tower
I used a BUSS relay and fuse block. 3 relays control the 2 fans for low and high speed operations. Power supply for the block comes from the pass through distribution block on the firewall.
Old Nov 15, 2025 | 08:08 AM
Car: 1989 Firebird
thank you, very nice set up !!!
Old Nov 15, 2025 | 10:35 AM
skinny z's Avatar
What brand and model fuse block did you go with?
I'll be revamping most of the engine bay wiring to better incorporate the add ons. Fuel pump, fans, ignition box all could stand for a better grouped distribution.
I've been looking at fuse/relay centres like this:
Although the one above is a little below the standard I'd like to end up with.
Old Nov 15, 2025 | 12:38 PM
Car: 1989 Firebird
I went with a PSI conversion and ls1 ECU along with a Ron Francis dual fan relay kit
Old Nov 15, 2025 | 02:31 PM
skinny z's Avatar
Do you have links to (rather than my looking it up) to what you're getting?
As I said, the wiring is a project (which I'm no stranger to as it's my daily job at the moment) and I'm looking to gather any and all ideas for a path forward.
Old Nov 15, 2025 | 09:20 PM
soloc4's Avatar
Metri-Pack 280 Sealed MINI®/MICRO® Fuse & Relay Panel - 30 Amp, Partially Bussed
This is what I used. 3 relays for the dual fans (low/high speed wired like the GTO) and 2 for the headlights low/high beam respectively.
Old Nov 17, 2025 | 04:09 PM
Car: 1989 Firebird
What engine and computer are you going with? I am still using the car fuse box of all the care needs and the engine harness for my LS1 came with fuel pump relays to go under the dash
Old Nov 17, 2025 | 04:43 PM
skinny z's Avatar
All old school here. No computer. No EFI. But I've added an electric fuel pump, an ignition box, aftermarket gauges (9), dual fans, a 5 volt constant output power supply (for a stand alone MAP sensor to go with the data logger).
The fuse block is packed with plug in Pico connectors as it it is and I'd like to clean that up. Same with the relays. I want to get them off of the firewall and into a central location.
Three of the above accessories are powered by inline fuses right off the battery and it's messy. I'd also like to eliminate the three fusible links coming off the starter and replace them with proper fusing.
A relay/fuse centre is what's needed. That'll neaten things up and also allow me to thin out the factory harness and eliminate some of my extra wiring.
85raideROC
Jul 18, 2012 03:59 PM
Conor
Jul 28, 2005 12:10 AM
camaro 670087
Jul 28, 2003 12:45 AM
Chuck Haynes
Jun 30, 2003 02:24 PM
