I Think My ECM is fried
Car: 92 camaro RS
Engine: 305 TBI
I have a scan tool for my 1992 Camaro RS I was having problems getting the car to start so I ran the scan tool on it usally the first thing i do whenever I have a problem. Well when I tried to pull the codes out nothing happend at all no check engine flashing not even once. PLEASE HELP ME!!
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
check all connectors in the back of the diagnostic plug. you probably have a loose/bad one. if your ECM was fried it would probably just send a bunch of
codes to the scantool. good luck!!!
codes to the scantool. good luck!!! Senior Member
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
The SES light has to come on when you first turn the key to on. With key on engine off, jump terminals A & B of the ALDL. You should get a code 12 minimum. If not, the ecm isn't working but it doesn't mean the ecm is fried. It could be a burned fuse or other silly things but it could also be a bad ecm. Give the ecm a "sniff" test. If it smells burnt, you let the smoke out of it.
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
