Disconnecting battery-will ECM loose IAC adjustment
Old Aug 16, 2002 | 11:18 AM
CHEVYTOWN's Avatar
I was wondering, if I disconnect the battery, I know that all codes will be erased.
What about the adjustment I made to the throttle stop screw concerning the IAC? Will I have to do the procedure all over again?
(I bought the system from Howell and I had to adjust the throttle stop screw, like they said, cuz it was turning off on idle.)
THANKS HOMETOWNS....CHEVYTOWN
Old Aug 16, 2002 | 01:51 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Disconnecting battery-will ECM loose IAC adjustment
The IAC has no functions that are learned.
It just rsponds to various inputs, and then goes to a park posistion when you turn the key off, so that when you try and start it again it's already reset.
Old Aug 17, 2002 | 01:54 PM
CHEVYTOWN's Avatar
thanks a lot G...stored in the data banks up in me head.....CHEVYTOWN
J-money
Jan 4, 2019 09:45 AM
skeltor
Feb 2, 2016 10:37 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
dimented24x7
Sep 6, 2015 03:51 PM
greenyone
Sep 2, 2015 03:39 PM
