winbin speed density calc problem
Old Sep 14, 2002 | 01:05 AM
xookered's Avatar
I changed the calc from 159 to 173 based on the formula to increase displacement from 5.7 to 6.2 liters. But everytime I leave winbin and come back the value is 40000 plus. What's the deal? All my other changes are just the way I left them. I've tried it on several aujp files and it's the same on all of them. If that number is correct the motor will blow up. What gives?
Old Sep 17, 2002 | 11:13 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
What ECM? I assume you are changing the BPW? I noticed WinBin has a problem with double byte values.
Example: If you have a DB value of $0052 and change it to $0053, I noticed WinBin will assume you want BOTH bytes $53. Meaning instead of leaving it $0053 it changes it to $5353. BIG difference...
Old Sep 18, 2002 | 06:06 AM
xookered's Avatar
I converted from the 165 to the 730 ecm. You hit the nail on the head, Astro. I was trying to change from $009F to $00AD an winbin kept doubling to $ADAD. It ended up being a bad ecu file. I changed to the 730v.3 and everything works right. Too many buggy ecu files circulating. I think it would be wise for me to jump on the Tunercat bandwagon when I get the dough. Seems winbin is a continuous work in progress.
Steve78LT
Feb 24, 2016 12:15 AM
Keith5
Aug 27, 2015 04:37 PM
nuggie
Aug 25, 2015 01:27 PM
jbd1969
Aug 17, 2015 07:06 PM
86Base
Aug 8, 2015 01:34 PM
