Are the 7730 and 6344 ECMs the same?
Old Sep 25, 2002 | 07:47 AM
JD68Camaro's Avatar
I was told that the GM tuned port ECM 16196344 was the same ECM as the 7730 is that right if so can you use the some chip and everything on it?
JD
Old Sep 25, 2002 | 04:39 PM
Gary Anderson's Avatar
JD,
It is an updated version of the '730. I have one in my car and all '730 software works just fine.
Regards,
Gary Anderson
Old Sep 26, 2002 | 07:59 AM
JD68Camaro's Avatar
Gary does it hook up any different then the 7730?
Thanks JD
Old Sep 26, 2002 | 08:06 AM
JD,
It is physically the same as the '730, wire harness connectors and all. The difference is internal and is just an upgrade, all '730 functions are the same. It probably has more capabilities than a '730 but I don't have that info.
Regards,
Gary Anderson
Old Sep 26, 2002 | 09:44 AM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
There is also another upgraded number being 16198262. Same thing just better. That's why it's an upgrade.
Old Sep 26, 2002 | 11:38 AM
JD68Camaro's Avatar
Thanks guys!
I guess I sould have waited I just found a 7730 and got it I want a spair one, I have a 7730 I may get me one of the others later if theya are better computer.
Old Sep 27, 2002 | 11:49 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
what makes the 262 better than the 730?
Old Sep 27, 2002 | 05:50 PM
hectorsn's Avatar
Car: 78 Regal
Transmission: M20
Axle/Gears: 4.10
It's an updated number which means they probably updated a few parts or made the PCB a better design. It's just an update, it doesn't do anything special or doesn't do any other functions.
Old Sep 27, 2002 | 10:42 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Guess I'll stick with ole reliable (730) then.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
