Tach says 5400, Holley 950 says 4350...
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
How likely is it that the Tach is wrong? Could it be the Holley Commander 950 that is wrong?
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
If anything the tach is slow. And the tach would say 4350 and the ECM 5400. Is there a 6 cylinder setting for the tach or something?
Nope, appears to be the other way around, the ECM definately reads higher, and the rpm logged by the ECM is consistent with the trap speed encountered at that rpm, and much closer to being mathematically correct than the calculated speed based on the factory tach.
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
