Help printing maps with DFI 6.32
Old Nov 18, 2002 | 10:50 PM
406-Z's Avatar
Car: 87 IROC Z-28
Engine: 406-Mini Ram-AFR 195's-DFI Gen 6.32
Transmission: 700-R4 w/Art Carr converter
Axle/Gears: 9" - 31 spline - 3:89
I was trying to remember how to print say the base fuel map in Accel. I remember having to type in "graphics" at the "c: prompt" or at the "c:/calmap " prompt and then when you are in the base fuel map you press "shift/print screen" and it would print the map. All I can get to print is the outer parameter of the graph and none of the info in the map. I was able to print all of the maps at one time but can only get the outer parameters to print now. What am I doing wrong? Thanks for you help in advance.
Old Nov 21, 2002 | 07:27 AM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
what i do is hit print screen then open "paint"click edit then paste and there is the screen you chose, but its all black like the calmap screen-way too much ink used up-so click image and then "invert colors" and print it on one page. prolly an easier way but this is doing it for me
DFI79MC
May 5, 2010 05:15 PM
vetteboy86
Jun 1, 2007 10:05 PM
junkcltr
May 31, 2006 07:00 PM
dahlman
Dec 25, 2002 04:59 PM
