open loop/BLM question
Old Nov 23, 2002 | 10:50 AM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
I have an 85 305 TPI with an 870 ecm. My question. When in open loop ( when you first start cold ) and using the tables, is there any value in there from the BLM that was last used that is added or subracted from the tables. Just trying to sort out different things I see on my winaldl.
Bob
Old Nov 29, 2002 | 08:04 PM
Chevero's Avatar
If your question is "will the BLM from the last run still be active when re-starting again from cold (open loop)", the answer is yes.
The ECM will not alter or update the BLM until it achieves Closed Loop status, but it remembers history unless it is reset by disconnecting the power source or a dead battery. The Closed Loop learning process for BLMs goes on forever, and the history is used whenever the engine is started.
Old Nov 29, 2002 | 08:32 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
The ECM will not alter or update the BLM until it achieves Closed Loop status, but it remembers history unless it is reset by disconnecting the power source or a dead battery. The Closed Loop learning process for BLMs goes on forever, and the history is used whenever the engine is started. [/B][/QUOTE]
Thanks much for the info. That is certainly the kind of indications I was getting and it all makes my reading more logical.
Frozer!!!
Jan 19, 2024 04:55 PM
lt1z350
Aug 28, 2015 05:57 AM
CORV3TT3
Aug 23, 2015 11:26 AM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
