TPI Computer Question
Old Nov 25, 2002 | 05:46 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I am having a problem with reading my codes. I am getting a "veh. not responding" the problem is that its running fine but it did have a incident where it backfired and bucked a few times. I thought it was in limp home mode but it Starts good......runs good.....has power it always did. Could the computer still be bad and the rest go so well.
Thanks for the input
Brian Felts
Old Nov 25, 2002 | 09:21 PM
funstick's Avatar
is the ses light on ??
Old Nov 26, 2002 | 05:59 AM
No, no light I got a code from it a few weeks ago for the EGR. Thats how I know the ALDL is working.
Brian
Old Nov 26, 2002 | 02:11 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
another one along the same lines-when the key is turned to run-not start-does the check engine illuminate at all? are you able to induce a code by disconnecting a sensor or 2? what are you using to pull codes? didja try the ancient yet still useful, a plus b plus paperclip=flashing trouble codes? need more info. has anyone been futzing around under the dash that didnt have proper clearance to perform such a task? CAR STEREO/ALARM INSTALLERS? hacking gleefully away-look at all the pretty wires, snipsplicetapeoopsyikes
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
