Programming (newbie)
Old Dec 28, 2002 | 10:36 AM
DarkSideOfTheMoon's Avatar
Hey there ~~~I have been playing with TunerCat and the bin for my 870 ECM. (I know....the 870 blows..but it is what I have money/time for right now)
Anyways, I am looking to adjust for the larger engine (305-->350 swap),larger injectors (22#--->24#) and added fuel pressure. The engine also has a *mild* cam. I am still a little confused when it comes to load factors vs maf etc.
Therefore, is there software out there that I can input my general engine setup...ie compression ratio,ignition system,maf or map,cam duration, etc and get a good fuel curve setup along with timing advance curves? I have finally got the car running smoothly...and now would like to start tweaking to pull the rest of the hp outta it. Thanks much....
Rob Hamilton
Chicago IL
1985 Trans Am
350 (.030 over)
24# injectors,AFPR,Cold Air Intake,Flowmaster Cat-Back,700R-4 w/2500 stall,corvette servos
Old Dec 28, 2002 | 10:38 AM
One other thing..I am using a 85 Corvette bin file (22# injectors/700r-4)
djmarch
May 8, 2016 11:32 AM
rubblerubble
Mar 13, 2016 06:57 PM
ULTM8Z
Oct 2, 2015 01:25 PM
bdads
Aug 24, 2015 06:01 PM
R3500
Aug 24, 2015 09:05 AM
