ECM Type?????
Old Feb 27, 2003 | 07:11 PM
89Iroc-ZL98's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 5.7L TPI
Transmission: WC T-5
ECM Type?????
How do I know what type of ECM I have (165,730,727,749,.......). Can someone give a brief discription of the differences?
My car is a 1989 TPI 350 with MAF.
Old Feb 27, 2003 | 09:07 PM
ozzga's Avatar
The ECM that came in 1986-1989 TPI Fbody's and Vettes is a series 1227165 (165). The ALDL data rate in this model can supply diagnostic data at 8192 BAUD. The (expanded) data stream of 64 Bytes cycles through every 62.5 milliseconds (16 per second) at this BAUD rate.
from http://www.eecis.udel.edu/~davis/z28/
check it out.
Old Mar 1, 2003 | 04:26 PM
Engine: 5.7L TPI
Thanks.
As I couldn't really clarify this question on the site, what are the differences between the different types of ECM, as far as what they work with. Is the 165 used in all MAF TPI's, and the 730 for SD TPI's?
Old Mar 2, 2003 | 01:33 AM
ozzga's Avatar
yes, the 165 is used on MAF cars, the 730 on MAP. the 749 is used on several turbo GM cars/trucks.
Old Mar 2, 2003 | 10:03 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
With software changes, GM cross breeds the various ecms.
ie the 1227165 was also used in single barrel S10 TBI systems. In the Australian version of the 165 (called the 808) it's MAP.
The 1227730 was used in TBI, MAF, and MAP applications.
Just a matter of wiring, firmware and software.
Old Mar 3, 2003 | 12:19 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Huh...I didn't know that the 730 was used in TBI apps. I've been all over the DIY ftp site and I haven't come across anything like that.
I have a 730 sitting on a shelf right here. One of these days I might get board and switch over to run my TBI setup.
Do you have any more info on that?
Old Mar 4, 2003 | 09:01 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
It was used on a 4 cyl TBI.
The injector driver in the 730 can do one P+H TBI injector, 2 P+H Port injectors, or 8 saturated port injectors.
I think the bin was an ABBT. Was years ago when I looked at it.
If you want to run a TBI with a P4 ecm, then look at a 749. I've run a 2 brl TBI on a 749. Other then the faster ALDL not worth it in my book. Might look at a later model TBI PCM. Just have to see what the flags are for VSS sensing.
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Briandrex
Oct 5, 2015 06:20 AM
bjpotter
Oct 4, 2015 07:48 PM
